15 t jack for my early Tiger I
Roland Mann
Been liked: 19 times
Post by Roland Mann »
Hi all,
I have tried to get a ready to fit 15 t jack to complete my early Tiger I . No way as fare as I went. So best was to create my own built. Based on the Photos from Rob Veenendaal I made a set of drawings and started. Here are the first results for those interested.
Roland
[/img]Image
(Hurra, got the photo transfered from Phptobucket)
Image[/img]
Der Weg ist das Ziel.
Steve Norris
Has liked: 8 times
Been liked: 701 times
Post by Steve Norris »
Hi Roland,
Brilliant :D , Is this a one off or do you plan on producing some more of these ?
Kent Wiik
Post by Kent Wiik »
Hi Roland
You are the man!
My god you German builders are amazing, you are better then us Swedes... :shock: - hats off!
Roland Mann
Thank you for the flowers Kent as we say here in Germany. I know the parts look dirty but believe me it will be nicer after shot blasting.
Sorry Steve, this will be a one off. It is just not economical for me with my kind of tooling to produce a batch.
Next step will be the shot blasting and mounting the gear box with rivets.
Roland
Steve Stuart
Has liked: 264 times
Been liked: 195 times
Post by Steve Stuart »
Hi Roland
The jack is brilliant! As an alternative, any chance of supplying plans for the jack? It would be a real challenge for me to make one, but it would be good to try!
Tim Bowman
Been liked: 177 times
Post by Tim Bowman »
Remarkable Roland! Super work as always!
Erstaunlich!
Has liked: 1485 times
Been liked: 1695 times
That's another photo where it's impossible to judge the scale of the parts :D
Can't wait to see it built up and operating :!:
Roland Mann
Thank you all for your nice comments. And yes Adrian, I can't wait to the moment when I lift up one corner of my Tiger with the jack. This time all material is steel and strong enough to perform for a real lift.
For those interested, the first two gears sets are module 0,5 while the final is 1,0. Most difficult to perform are the axles distances. With the first pair of gears it is 11,25 mm and the second it is 16,25 mm.
The gear box halfes are 1,5 and the other 1,0 mm in thickness.
Here the parts after shotblasting and ready for closing the gearbox by rivetting the halfes.
Best regards Roland
another master peice from you roland,what a build when finished,superb!
simon manning
Roland Mann
Hallo Steve Stuart, sent you a P.M.
Thank you Simon for your comment. I will have a very motivated way for my next steps. Rivetting is the next. The rivetts will have a 1.4 mm shaft and the head Ø will be 2.5 mm. The material is copper and there are only 33 to fit.
Roland
Jeffrey Goff
Has liked: 20 times
Been liked: 737 times
Post by Jeffrey Goff »
Hi Roland, superb craftsmanship, like all your other work this will be a work of art
regards Jeff
Jeff Hyder
Been liked: 3 times
15 Ton Jack
Post by Jeff Hyder »
Hi Roland,
I am going to have a cup of tea!
Cheers Jeff Hyder.
Fred Lopian
Post by Fred Lopian »
Klasse Arbeit Roland.
Super work Roland.
Much greets from Leipzig
Fred
In memory at Kurt Knispel (s.Pz.Abt 503) -- 168 victories
Pierluigi Patri
Been liked: 1 time
Post by Pierluigi Patri »
Hi Roland
A piece of art like your 88 mm gun.
It is really a pity you do not make a batch.
Pierluigi
Matthijs Dijkstra
Been liked: 2 times
Post by Matthijs Dijkstra »
Roland,
Outstanding Super Toll WOW !!!!
Matthijs
