Hello
I disassemble my M2 to repaint it.And when I turned the inside dia. of tires,I made them a tight fit to the road wheels.But there too hard to get off,and there's no room for glue.So my question is what is a good fit,or how tight should they be? I have to glue them in place,because they will slip off if you don't.Thanks guys from Dan.
Road wheels/tires
- Has liked: 1475 times
- Been liked: 1674 times
- Been liked: 15 times
Hello Dan
The tyres are supposed to be a tight fit so there is no need to glue them on. How you fit the tyres is to heat them up in a pan of hot water for 10 mins or so they will then be soft enough to fit over the rims. Hope this helps.
Lee
Lee
If its not broke dont fix it.
Ich Hatt Einen Kameraden
Hi Guys,Yes I was talking about the 16 bogie wheels I called them road wheels.There made from nylon stock.All of them had to be turned on a lathe.I made them fit tight,But some came off 1/8" with the vehicle running.
And that is why they must be glued on.I will have to play with the fit of these,when I get to this part.To clear this up there are 8 bogies wheels,4 per side,with two tires per wheel. Thanks from Dan
- Has liked: 4 times
- Been liked: 16 times
