Martin's Sturmtiger
Martin Hofmann
Has liked: 150 times
Been liked: 1940 times
Martin's Sturmtiger
Post by Martin Hofmann »
Now i am starting a new project: I think one of the last Sturmtiger out of the box.
The first photos are from the hub caps and the sprockets with the rings. The next are coming.
Regards Martin
Derek Attree
Has liked: 219 times
Been liked: 197 times
Re: Martin's Sturmtiger
Post by Derek Attree »
Hi Martin
Years since there has been one of these on here.
Will be following the build with interest.
Regards Derek
Been liked: 1715 times
Looking forward to this Martin, regards simon.
Robert Tanzer
Has liked: 1086 times
Been liked: 957 times
Post by Robert Tanzer »
Really looking forward to following this build.
Robert T
David Brady
Has liked: 197 times
Been liked: 737 times
Post by David Brady »
Also looking forward to following
Prototype sturmtiger here
Martin Hofmann
Thank you guys for the warm welcome,
here are the next photos of the road wheels. On the last photos you can see, that the screw 2 and 4 of every 5 screws are soldered to simulate a screw and not a nut.
Regards Martin
David Brady
Nice work Martin I will do the same on my Late tiger and Sturm.
Robert Tanzer
What fine details, Martin.
Wonderful to follow this build.
Martin Hofmann
Hi David,
hi Robert
thank you so much for your nice words. But i was to early with mounting the Aluminium sprocket rings from Armortek. In the meantime i ordered the beautiful tracks from Liam and his sprocket rings made of steel. The absolut best tracks for a Tiger 1 i ever saw!!!
So i had to dismount the alu rings and mounted again with the steel rings. Also the road wheels and the swing arms are ready and primed.
Regards Martin
Robert Tanzer
Agree with you martin 110%
Liam's late Tiger links are absolutely beautiful.
I have them on my Late Tiger also. :D
Mark Weiss
Has liked: 13 times
Been liked: 81 times
Post by Mark Weiss »
Martin the detail work on the road wheels was superb. The smaller m2.5 nuts on the hub look fantastic and the faux bolt heads look perfect, especially with the larger m2.5 rim nuts. Did you use m2.5 nuts from MVD? That was where I was going to source mine for my KT wheels.
Martin Hofmann
Hi Robert, Hi Mark,
thanks for the very nice words.
Mark: i used nuts from company Knupfer here in germany they are called: Modellbaumutter. They have a smaller key width than the DIN nuts!
Here are some more progress on the parts of the chassis. The axles are glued into the arms with LOCTITE 2701 and after this the swing arms are drilled and pinned with spring dowel sleeves like all my tanks.
Regards Martin
Robert Tanzer
As usual beautiful work Martin.
Robert T
