Wiring Question
Wiring Question
Newbie here! I've built and wired a few rc vehicles, but this is my first tank. I'm used to drive being synchronized. However, if I've wired this (leopard) correctly, one track is controlled by moving the stick L/R and the other by moving the stick U/D....Therefore, the way to get straight forward motion is to move the stick to a perfect 45 degree angle - with slight variations clockwise or counterclockwise resulting in turns. Does this sound correct? I haven't missed something like a Y cable somewhere, have I? Thanks in advance!
- Has liked: 1484 times
- Been liked: 1687 times
Re: Wiring Question
You need to mix the two stick directions together in the transmitter so that moving the stick affects both track channels together.
What transmitter do you have ?
Re: Wiring Question
Thank you! It's a FlySky PL 18 EV Paladin. I'm not in front of it at the moment, but I get what you're saying and that sounds like something I should be able to get in there and figure out. It seems to have a LOT of programable features. Thanks again.
Re: Wiring Question
A friend uses one and it seems to work very well. Except I have to upgrade the RX firmware everytime he buys a new tank
I think this is the section you want.
- Has liked: 29 times
- Been liked: 91 times
Re: Wiring Question
I have the Paladin EV18, I love it in fact. I use both single stick and the individual track sticks on the side of the radio. I use a button on the radio to switch back and forth. I watched the Hobby Concepts video to learn how to program it. He has a series of videos on the radio. Hope this helps.
Regards,
Regards,
Re: Wiring Question
Thank you! I'm at work, but I have that exact video queued up and ready to watch this evening when I get home. Bob (from Hobby Concepts) is great! I previously bought a Beier sound system from him (and will probably buy another one now...) I thought about switching to the dual levers for motion, but with your tip, maybe I'll setup both and see which I like better. I appreciate the response and advice!
- Has liked: 1121 times
- Been liked: 990 times
Re: Wiring Question
Thank you Mark Weiss
I have the same radio, thanks for the tips about the videos.
Have a nice day
Robert T
Have a nice day
Robert T
