JagdPanther G2 Robert 2024
chris fry
Been liked: 525 times
Re: JagdPanther G2 Robert 2024
Post by chris fry »
Hello Robert,
Good idea with the jig, Just be carful with 480 you don't get any glue between the tyre and jig or it will stick them both together, Forever.
Quick question on one or your last posts, The picture with the suspension arms/axles all fitted, is that the angle you have set them all at !!!,
Regards, Chris.
yves mouton
Been liked: 741 times
Post by yves mouton »
Hello Robert,
I use tie straps to secure the rubber rings on the wheels.
Best regards Yves
Björn Johansson
Has liked: 481 times
Been liked: 408 times
Post by Björn Johansson »
Love to read about you´r build here Robert .
Hope to be able to see it in real any day soon :D
Kind regards from Björn
Robert Tanzer
Has liked: 1122 times
Been liked: 990 times
Post by Robert Tanzer »
Small update on the sprocket wheels.
I had to wait forever for my castle nuts and other hobby screws.
My friend Christoffer A here in Sweden, did help me with making M3 screws with the correct scale head.
These are the ones that hold the brass washer.
After that I made new hubcaps, so that the brass cover plate hides the M3 screw.
Have a nice hobby time to you all.
Robert
Robert Tanzer
After looking at many pictures and many books about JagdPanther, I found a small detail I wanted to do on my hubcaps.
Many thanks to my friends who helped me measure the diameter of that hole.
There were a few holes to drill, but it's like therapy to do this.
Have a nice day to you all.
Robert
Has liked: 748 times
Been liked: 360 times
Post by Christoffer Ahlfors »
Beautiful hubs! :D
Andre Meylan
Has liked: 802 times
Been liked: 362 times
Post by Andre Meylan »
Simply amazing ... keep on Robert !!!
Cheers, Andre
Robert Tanzer
Thank you for your nice words
Robert T
Robert Tanzer
Small update in the wrong order.
I decided to be able to screw my hubcaps on with all the washers.
So I used my lathe to make inserts, and drilled and tapped the holes for the hubcaps.
Have a nice panzer time :D
Robert T
Robert Tanzer
I found a new detail that I want to do on my JagdPanther.
It took a while to make these washers, but now I'm on my way. :D
Have a nive Panzer Day to you all.
Robert T
I don't think I have seen anyone do those? :D
Marco Peter
Has liked: 1538 times
Been liked: 798 times
Post by Marco Peter »
Outright MADNESS! :mrgreen:
'Konan', my Tiger 1 Mid
'Gunther', my Panther G
Didier Molard
Has liked: 61 times
Been liked: 99 times
Post by Didier Molard »
]hello.
incredible details added to your Jagd.
Just beware, on every picture i've seen , the locking tab are oblique on the wheel, probably due to the fact that when tightening the nut, the bolt head was rotating,then the tab came in contact with the side of the rim and blocking the screw, enabling to finish the tightening (so you do not need to holt the bolt head)
Didier
Robert Tanzer
One done, only the rest left to do. :D
Has liked: 163 times
Been liked: 849 times
I don't see this detail on every wheel? Does anyone know if they came from factory with this flange on every wheel nut? Or just certain wheel stations? Lots of images without the flanges.
Just curious?
