Advice please 🙏
David Brady
Has liked: 213 times
Been liked: 840 times
Re: Advice please 🙏
Post by David Brady »
Hi,
No hasp and staples available, I had the last set from Steve.
Clive Armitage
Has liked: 25 times
Been liked: 40 times
Re: Advice please 🙏
Post by Clive Armitage »
Thanks for letting me know.
Clive Armitage
Has liked: 25 times
Re: Advice please 🙏
Reaching out for help trying to understand the wiring.Where does the receiver get its power from? as it is.Lower volts than everything else
The receiver is a Spektrum AR8010T thank you
Has liked: 1480 times
Been liked: 1685 times
Re: Advice please 🙏
The receiver is fed from Motor Control A.
Riny Koks
Has liked: 1037 times
Been liked: 100 times
Re: Advice please 🙏
Post by Riny Koks »
Hi Clive,
I would buy a BEC 5A to supply the receiver.
The power out of the motor control (sabertooth) is very low, it can cause errors.
The bec should be 24v to 5v 5A which will be enough to supply the items connected to the receiver (eg servo's, lights)
The red wire from both motor control boxes (4x) should be disconnected on one (or both) sides.
Riny.
2019 M3 Lee #25
2022 Panther G #6
2014 Sd Kfz 7 #6
Pak 43, Flak 36
Bailey Bridge + Extension
Clive Armitage
Has liked: 25 times
Re: Advice please 🙏
Thank.
You so much for your quick reply .I will order the unit. The red wires have been cut on motor controller B not on A I will do that.
I have also noticed all the black connectors going into the receiver have been trimmed to make them fit is that normal . Also please can you tell where to plug the power into the receiver Clive
Been liked: 1839 times
Re: Advice please 🙏
Hi Clive
White (Futaba) orange (JR) sometimes yellow (Hitec) are the common signal wire colours. Definitely not black or brown which is usually common negative or red usually supply + positive.
Don't mix them up, it may blow something up or severely damage it.
I have used motor control A to supply the receiver in the hull via it's BEC. Disconnecting out coming red plugs from Motor control B's BEC which plugs into the receiver.
I believe the BEC's to be switch mode outputs from the motor control red boxes. What ever they are, some receivers dislike two incoming supply inputs. There were some conflicts wiring wise early on with the Chieftain build.
I'm not an expert on switch mode power supplies, other members might be. Just be careful you get the polarities correct otherwise it could become expensive.
Paul Sparkes
Has liked: 97 times
Been liked: 243 times
Re: Advice please 🙏
Post by Paul Sparkes »
Also never run 2 BEC or ESC with BEC, thats the reason the red wire on module B has been cut. If you use a seperate BEC (usually better) then cut the red wires on Module A also.
This is probably beyond some builders so best stick with what Armortek instruction say unless you know exactly what your doing.
222 scout car
Clive Armitage
Has liked: 25 times
Re: Advice please 🙏
Hey a big Friday night
Thank you And a glass of wine on me If we ever meet i'm learning and it's stretching my mind which is why I wanted the project.
I hope to avoid the smell of burning however if it happens it happens with your advice all should be well next question to follow soon 😀
Re: Advice please 🙏
There are two styles of servo plugs.
The Futaba style has a lip running down the side of the plug, which mates with a slot in their receivers, so that you can't plug them in the wrong way round.
Spektrum receivers don't have that slot, so you can't plug in a Futaba plug, even if it's the right way round, which is why the lip has been trimmed off.
When ordering leads, it can be a lottery as to whether you get plugs with the lip on or not, even when buying none Futaba coloured leads, which are the white/red/black ones.
Clive Armitage
Has liked: 25 times
Re: Advice please 🙏
Thank you very much Adrian
Clive Armitage
Has liked: 25 times
Re: Advice please 🙏
Has anyone re-engineered the breach?I'm not happy with the aluminum barrel rubing on the aluminum breach I am considering using a Flanged Linear Ball Bushing.
Re: Advice please 🙏
I've not looked at this on the Chieftain but according to the manual, ES0704 is the recoil bush and the barrel should slide in this.
The recoil bush is usually nylon I think.
Clive Armitage
Has liked: 25 times
Re: Advice please 🙏
Hi, Adrian, thank you so much. That explains it the nylon sleeve isn't in the recoil kit, so it must have been provided with the original build. I haven't received that from the original owner..
I'm still tempted I know it's over the top to put a bearing in.
Re: Advice please 🙏
Yes, it came with the kit (shown in build section 36).
