My Stug conversion
- Been liked: 10 times
- Has liked: 126 times
- Been liked: 758 times
- Has liked: 218 times
- Been liked: 182 times
Hi Guys
Well the roof has taken much longer than I thought it would
But the extra effort has been worth it.
So here are the pictures.
All the bits to make the roof.
here you can see the angles on the joiner parts.
In Close up.
Machineing the holes with a boring head on the mill (not a lot of fun it was a bit bouncy)
The whole thing is very solid and I would like to thank Dale
for his imput in going this route with the roof .
I am well pleased with the result
The screws round the edges will be hex head like the real thing.
but I used csk just while machineing the hole. The screws that
are on the joiners like the others in the sides and back will be filled
with good old P38 before painting.
The next job is the coupler mounting tube.
A nice little turning job.
In Close up.
- Been liked: 429 times
- Been liked: 177 times
Hi Bob
Thanks It does seem nice and solid.
I am now working on the tube to mount the coupler and I
have also done a bit more on the gun mount tube and mantlet.
That is to take Dave Dibb's (Armorpax) very nice barrel and
muzzel break.
Weight could become and issue and I am going to weigh all the parts
of the PZIII turret and the mounting box at the weekend to see how the
stug unit shapes up.
If nessasary I will lighten some parts so not to overload the chassis.
muzzel break.
Hi Guys
I have been doing some more work on the gun and Mantlet.
Here are some pictures.
First up mantlet and recoil tube.
Dave Dibbs barrel.
Dave Dibbs Muzzel break
The muzzel is only together with sticky tape still lots to do
with detail on mantlet and recoil tube.
Dave Dibbs barrel.
Hi Allan
Yes the Mill is a bridgport clone that I have in my small shop at work .
It has full range of speeds (vairyspeed) from 60 rpm to 2600 rpm the low speeds less than 500 rpm are with a back gear.
I have today finnished mounting the coupler tube and I should post the pictures over the weekend.
To me that has really bought the stug to life.
I am also starting the slide cover for the scope hole in the
front of the roof.
front of the roof.
Excellent Derek! I enjoy every post and every photo of your project! Dave's cupola really finishes off the fighting compartment. I can only imagine how good this will look as you add the smaller detailing. You will have a one of a kind masterpiece.
Keep up the great work.
