Tiger blank firing Unit
- Has liked: 4 times
- Been liked: 24 times
Hello Members,
I have a new tiger firing unit. It has never been mounted to a tank or fired. I only assembled the firing mechanism and tested it with a power supply. Just never got around to putting it in a tank and it’s been sitting. As you can see, I greased the gears well prior to storing. $450 plus shipping.
- Jerry Carducci
- Location: The People's Paradise of California, the former Golden State
- Has liked: 3 times
- Been liked: 1029 times
Re: Tiger blank firing Unit
General question born of curiosity: what sort of blank cartridge were these things designed for?
Or was it some sort of proprietary one-off thing?
I have blank firing units (for smaller models) that use 8mm theatrical blanks; I have three that I've never mounted or fired.
- Has liked: 254 times
- Been liked: 182 times
They use a 12 Gauge Shotgun Blank Cartridge, the shorter of the two lengths available.
The shipping seems to be between $50 and $90. This is an approximate cost going from Florida to London using USPS. I will take pics of the final cost and send it to you. I hope this helps
Wael
Wael
Hi Adrian,
The shipping quote is an estimate and I am sure Manchester would be within this estimate. If the shipping cost is more, I will cover it. I hope this helps
Regards,
Wael
Regards,
Wael
Hi Adrian,
The total cost will be between $450 and $490. I hope this helps.
Wael
Wael
