@ Robert:
https://booant.com/de-de/products/pvc-2 ... ttery-pack
Layout
- Has liked: 60 times
- Been liked: 147 times
Re: Layout
@ Malcolm
https://www.amazon.de/dp/B0BY5SSBNL?ref ... tails&th=1
Product descriptions
High quality high current plug
Original XT60BE-F plug with rubber cap and screws
The best high current battery connector on the market!
Like the original XT60, this connector is made of high strength nylon with gold-plated 3.5mm connectors, so that the XT60E-F continues to offer an excellent high-amp connection for applications up to max 60A. The XT60E-F connector system is the further development of the popular XT60 connector system and has additional edges for installation.
* Gold-plated connectors
* Long connection contact points for better current flow
* Replaces all connectors
* Small and light
* Current: 60A - 90A
* Weight: 24g
* Distance between mounting holes: 32mm
* Plugs offer a secure hold
* Perfect fit (worldwide standard)
* Highly resilient
* High conductivity
* Reverse polarity protection
* Tried and tested standard in the model building scene
* Easy to connect and disconnect
* For a secure connection and contact surface
* Excellent high quality
* High temperature nylon housing
* Minimal transmission resistance thanks to gold-plated surface.
* Tight fitting, for a secure connection and contact surface
* Excellent long-term use properties
* Quality nylon plug high current connector
* Easy to solder
Material: Gold plated copper
Max. RC/MC: 60A -90A
Weight: 8.0
Weight: 8g with cap and screws
Temperature resistance: -20°C ~ 120°C
Recommend Soldering Spec.: 480°C
Dimensions of mounting socket: 42x15x23mm
* Small and light
* Weight: 24g
* Highly resilient
* High conductivity
* Easy to solder
Weight: 8.0
- Has liked: 399 times
- Been liked: 877 times
Re: Layout
Thanks Rolf
Unfortunately for me Amazon Germany won’t deliver to the UK and Amazon UK don’t seem to stock any.
I’ll have to try and find some from elsewhere.
Malcolm
Malcolm
2022 Panther G #15
- Has liked: 775 times
- Been liked: 1740 times
