KIT No. 98 BUILD
Forum for discussion relating to the 1948 - 1950 Series 1 4x4 car
mick whittingham
Has liked: 10 times
Been liked: 213 times
Re: KIT No. 98 BUILD
Post by mick whittingham »
Spent the day wrestling the body work and cab floor into submission.
I've found it easier to pop rivet the pieces together then bolt into the chassis rails.
Doing this i have a nice sturdy construction with no rattles and a nice solid sound when I tap it.
I'm just trying to decide how best to paint these separate items; paint them off the vehicle and risk marking them as I bolt them into place, or paint the underside, fit to the chassis and mask before spraying the finish coats?
I'm sure it will all come together in the end.
mick whittingham
Has liked: 10 times
Another project within the wider build today.
While fitting the cab floor I thought a handbrake would look good. Nothing too flashy, just a turned rod fitted to the seat panel to the drivers left.
But I got absorbed in the idea and it kind of grew into a functional lever on a sprung pivot so that it can be set at an up or down position. Oh and I just had to make the release button something you could press.
It is a bit in the way of the drive battery but nothing that is causing a problem.
Charles A Stewart
Has liked: 504 times
Been liked: 915 times
Post by Charles A Stewart »
Very nice addition Mick.
I made my handbrake the on/off switch for the electrics :)
Take care.
Charles
mick whittingham
Has liked: 10 times
I was looking at that Charles but I concentrated on the spring detent. I guess it could make it again, but I tend to make things up as I go along and try to do things in one take lol.
I made a new gear lever base and knob this afternoon too, which looks good. I'll post a photo tomorrow.
mick whittingham
Has liked: 10 times
This is the new gear change lever and base, there are a few different designs on the various models.
I like the look of this one so chose to do it on mine.
mick whittingham
Has liked: 10 times
Continuing with the controls I made the high, low range
Lever in a similar way to the others.
I made an alloy base for it to pivot in and hopefully carry a microswitch to activate the electrical system.
mick whittingham
Has liked: 10 times
I thought about Charles idea to power the electrics using the hand brake. Having already done that assembly I decided to use the Hi-Low range lever instead.
Fitting a microswitch and return spring was relatively easy. But I needed a way to keep the switch in the off position when the model is static.
So I set a magnet into the gearbox housing to retain the lever in the forward position, then spring tension holds the switch on for running.
mick whittingham
Has liked: 10 times
Thanks to a clock repair that was handed to me I've been neglecting the build for a few days.
But I finished the spare wheel carrier off and moved a step nearer to painting I guess.
mick whittingham
Has liked: 10 times
I've been working on the cab floor assembly, filling and painting to get it looking good ready for the finish colour.
I'm happy with the gear levers, hand brake and pedals.
Now it's time to look at the seats and any modifications I need to do.
Then finish the rear load bed and body panels.
Feels like I'm really making progress now, looking forward to building my spray booth for the body panel painting.
