Churchill Mk3 number 67
- Has liked: 2263 times
- Been liked: 7149 times
Re: Churchill Mk3 number 67
Look very convincing regards Phil
- Has liked: 1371 times
- Been liked: 1567 times
I've got a Welbike kit on it's way, but it's literally on a slow boat from China. I ordered it in July
That exhaust system looks fabulous
- Has liked: 738 times
- Been liked: 1702 times
Hi AdrianAdrian Harris wrote: ↑Fri Sep 27, 2024 6:52 pmI've got a Welbike kit on it's way, but it's literally on a slow boat from China. I ordered it in July
Let me know when you get the Welbike as there are a couple of problems to avoid and parts not shown on the diagram.
Gary.
Hi all
I have added the brackets and 90 degree fittings to the exhaust boxes. These will support the shield plus the shield will have two support posts that appear to go directly to the deck. A bit more research is required to confirm this.
Gary
Gary
Hi all
A bit more progress this afternoon, I added the weld details on the exhaust box supports and connected the quick release fittings to the smoker tubes. The tubes needed heating with my hot air gun to get them into the right location but it means I only have to undo the six deck screws and four retaining nuts to remove the mid deck complete with all the exhaust system still attached.
Gary
Gary
Good morning all
I couldn't resist doing some weathering on the exhaust system, still some way to go but here is the initial result.
Gary
Gary
- Steve Lewington
- Has liked: 8538 times
- Been liked: 283 times
Hi Gary
Fantastic job you're doing mate.
There is no time for peace.
No respite.
No forgiveness.
There is only ......WAR.
No respite.
No forgiveness.
Hi all
I found another little job I had forgotten to do, namely the stud guards on the applique armour fixing points. I used 11/32" brass tube with M4 brass nuts soldered in place. I decided to leave a few off as photos often show some missing.
Gary
Gary
- Has liked: 8 times
- Been liked: 100 times
- Has liked: 766 times
- Been liked: 1739 times
Hi all
Due to a torn tendon in my shoulder I haven't been able to make much progress on the Churchill. Therefore I am progressing the stowage which will also be on the derrick.
I have a nicely detailed selection of Dave Dibbs tools to work on . The paints are water based acrylics with the odd oil paint such as used for the grease on the brush. The wooden handles are a work in progress as I try to get the right combination of colour, wear and age.
I find this kind of detailing very relaxing and satisfying, made all the easier by the quality of the tools and parts.
Gary
Gary
