New Tiger I parts
- Has liked: 2498 times
- Been liked: 443 times
New Tiger I parts
Tiger I, upgrade parts
With the new arrival of the Tiger I, I have put together a full inventory of my Tiger I parts on offer
W5-01 Tapered antennas £18
W5-05 Rubber antenna base (Liam Mahoney) in either the normal larger size or scale smaller size £17
W5-12 U Shackles x4 £36
W5-13 C-Shackle working as the original £25 each
W5-15 Mudguard slide bars £16 x4
W5-17 Driver/Radio operator hatch hinges £20 pair. These hinges come with Armorpax AP-059-GR hatch set as standard.
W5-18 MG34 cupola mount £55 Mid and Late versions
W5-20 Convoy light standard £17 and W5-20D Deluxe £26
W5AP-21L 20 tonne jack £55 this is the resin brass and white metal version
W5-22A Tiger I, working jack brackets £22
W5-29 Exhaust lifting lugs £8 x4
W5-36 Crew Heater cover £10
W5-37 Oil filler cap £4 (Mid and Late version)
W5-38 Tiger bump stops x4 £72 come with castle nuts
W5-39 Engine hatch locks £10 set of x4
W5-40 Turret vent £22 (Mid and Late version)
W5-41 Tiger hull vent £25
W5-42 Tiger engine hatch hinges £14 (with and without casting numbers)
These are just Tiger I Parts, I have parts to fit other Panzer including King Tiger and Panther.
All prices are plus postage and PayPal fee.
Orders can either be PM or werkstatt.five@gmail.com
- Has liked: 5 times
- Been liked: 653 times
Re: New Tiger I parts
Very nice. Don't suppose you will be making replacement hatch latches.
Yes, correct shape would be nice. What material are you using. Is it brass?
Yes, It's only the jacks that are resin, brass and white metal. everything else is brass.
- Has liked: 60 times
- Been liked: 4 times
Hi Mark,
I want to order from you! How can I reach you? I sent a private message and an email.
- Has liked: 218 times
- Been liked: 180 times
Hi Mark
I need to order some parts too but I am not sure is you have received my 2 pms and email from earlier this month.
Regards Derek
Regards Derek
- Location: Trapped behind enemy lines in the State of Washington.
- Been liked: 3 times
- Has liked: 272 times
- Been liked: 129 times
- Has liked: 3 times
Hi Mark, Did you receive my PMs?
Regards,
Regards,
- Has liked: 753 times
- Been liked: 61 times
Great service and great parts from Mark. I just received a nice tidy package from across the pond with a bundle of exquisite parts from Mark Lawson. I greatly appreciate the build/casting quality and professional service. Thank you!
Now if I could convince him to make SD Kfz 7 and 88 Flak parts....
