Martin's Panzer IV
- Martin Hofmann
- Has liked: 141 times
- Been liked: 1547 times
Re: Martin's Panzer IV
Now comes a small update with the new front cover of the turret, the ventilation parts of the motor compartment and the back plate with welding lines.
Regards Martin
- Has liked: 690 times
- Been liked: 660 times
Thank you for sharing your excellent work Martin.
Best wishes from Sweden
Robert
Robert
- Been liked: 45 times
Wie immer ein absoluter Augenschmaus, einfach geniale Arbeit
Gruss vom Uwe
Gruss vom Uwe
1:16 Models: Kingtiger
1:10 Models: Flak-Panther Coelian, Panther A , S.WS with 3,7cm Flak 37
1:6 Armortek Models: Flak 36 2006, Kingtiger 2013, Sd.Kfz.7 2014, PAK 43/41 2015, SdKfz 251 2016, FAMO 2018
1:6 other Models: Opel Blitz , Kübelwagen , Zündapp KS750 etc...
- Has liked: 578 times
- Been liked: 47 times
- Martin Hofmann
Hi Robert, Uwe and Damon,
thank you so much for your nice words.
The next step is to start with the electric and the doors from the turret, but all not ready!
Regards Martin
- Martin Hofmann
Here are a small update with the electric installations and the first painted and weathered road wheels from the inner side of the tank.
Regards Martin
- Martin Hofmann
The next step was to glue the bearings into the wheels with Loctite 648 and the rubber rings with Loctite 480.
In the middle of the covers i made a sunk hole and glued in a self made grease nipple. They are made from a cap screw M1,6 with a glued ball of 1,5mm diameter into the head and covered with a washer, so you can see the ball from outside.
At the last fotos you can see the layer between the chipping layers before the yellow layer is painted.
Regards Martin
- Has liked: 1174 times
- Been liked: 1358 times
They look excellent. I didn't know you could even get 1.5mm ball bearings
- Martin Hofmann
Hi Adrian,
thank you so much for the nice words. The balls in the cap screw head are only the balls with dia of 1,5mm and not the whole ball bearing
But for information : you also can buy bearings with an inner diameter of 1mm!!!!
Regards Martin
- Martin Hofmann
After the last chipping layer comes the paint of Dunkelgelb in two variations for the Afrikakorps. Then the chipping process is followed at the road wheels. The sprockets have to come next. Some wheels are only looking primed ( the red ones ), but have also the chipping underground. The wheels with the open bearing is only the spare one for placed at the side of the tank. Now the weathering has to be done.
Regards Martin
- Martin Hofmann
The weathering is done. So the road wheels are ready for mounting.
The idler wheels got the medium layer of the chipping process.
Regards Martin
