Panther G 2022 #15 Build
Malcolm.Plumb
Has liked: 460 times
Been liked: 952 times
Re: Panther G 2022 #15 Build
Post by Malcolm.Plumb »
Thanks Jae-seung, I have quite a way to still go with actual assembly first, so not for a little while yet.
I'm in no rush and don't seem to have as much spare time as I did last year anyway.
2022 Panther G #15
Timo Haehnle
Has liked: 57 times
Been liked: 75 times
Post by Timo Haehnle »
Malcolm.Plumb wrote:
Wed Sep 11, 2024 9:20 pm
The mounting for the commander has now been fitted and again I've test fitted the figure.
Looks like we have the same taste in the txpe of the commander fiugre. "Jaeger" is also the commander of my Hetzer :P
Malcolm.Plumb
Haha must be twin brothers then with the same name :wink:
That confused everyone when they signed up for duty :lol:
2022 Panther G #15
Malcolm.Plumb
Side rails and brackets sorted for now.
Rail is not fully tightened down to the brackets as it will be removed when I start the Zimmerit.
Now back onto the mudguards.
2022 Panther G #15
Malcolm.Plumb
More work on the mud guards.
I have used some brass rivets with the thickness of the head reduced just to add a little bit of detail to the stock parts.
Need to try to get some primer down tomorrow hopefully.
On to the Bosch head light next.
2022 Panther G #15
Malcolm.Plumb
I've started looking at the working headlight for the Panther.
Managed to get a high brightness SMC Led fitted and some 2.3mm aluminum tubing bent to run from the lamp to just inside of the mudguard.
Some more to do over the weekend hopefully.
2022 Panther G #15
Malcolm.Plumb
Mudguards and headlamp sorted.
2022 Panther G #15
